At this time of year, it always makes me wonder why GM never programmed in a block heater function.
I can't see why not. It's purely a software programme it has all the hardware already installed.
If you heat up the HVAC circuit and run it 'OFF' for more than 5 mins it goes cold. If you heat it up with the engine, it delivers heat for around 25 mins in 'OFF'.
Why not use the engine block as a thermal store? On electric heating it could heat up the engine block too and store thermal energy there. Also means you get cleaner more efficient engine running if you start up early in the trip on hold.
For all the clever thinking in the Volt, you sometimes wonder if it wasn't simply a bit of a rush job at the end. But if so, why not have implemented it for the Volt 2? It could be an extra option buried in the menus.
