Sounds like they based those rates off of cars with much higher charging rates (which is why I think they should charge by kWh, not total time). A tesla can charge at up to 80 A (I think), which means that the cost for charging would be around 4.5 c/mi at that max rate. Even a Leaf which can do a 6.6 kW charge rate would drop it to 12 c/mi, which is just a bit more than gas.
All this makes a good case for having a faster charger in gen 2 volt. If the public/pay per use charging infrastructure develops more around the pay-per-time model rather than pay-per-kWh, it will have a big impact on people considering a volt vs an EV with a quicker charge rate...at least in areas where public/pay charging stations are convenient to use....
