I know there are a lot of complaints about the OEM Goodyear Assurance tires on G1 Volts having a lot of blowouts. I have had a few myself and have replaced 2 tires in my 2013 Volt but now it's time for a full set.
I read a lot of recommendations on here for LRR tires but are those more prone to blowouts than non-LRR tires? Or is it just that they have to be replaced more often due to low tread? I read on here that the light-weight of the OEMs could be the culprit behind the high frequency of blow-outs (thin walls?).
Are these run-flat and self-sealing tires anything special? The only run-flats for G1 Volt on TireRack are Bridgestone Driveguard, which appear to be prone to blowouts. (!) I believe the OEMs were self-sealing but I still had to go in to the repair shop for slow-leaks due to nails.
I would like to avoid a huge drop in AER (no more than 10%).
So does anyone have a recommendation on a long-lasting, durable tire that won't impact AER too much? Or are some of those aspects mutually-exclusive?
