Is it fully covered under the extended GMPP warranty?
Thanks
MrEnergyCzar
Thanks
MrEnergyCzar
Some mild, almost inaudible whine is normal at low speeds when the car is starting out or slowing. At least, I hear some. Not objectionable or bothersome, though I suppose some with more sensitive hearing may hear more or be bothered. A bearing failure leaves no doubt in the driver's mind that something is very wrong. Dogs start howling and pedestrians will turn to see where the noise is coming from. It's not a subtle thing.Some,very mild "whine" during regen is normal, right ?
The bearing repair is certainly covered under the 3 year/36k bumper to bumper warranty. If it's considered part of the power train—the engine, the transmission/transaxle, and the drive train—(seems like it is part of the power train to me), that warranty is 5 years/100k miles. Any Voltec componenet is covered 8 years/100k miles. I don't think the bearing would be considered a Voltec component. A GMPP Major Guard warranty extension of that would seem to apply as it coversIs it fully covered under the extended GMPP warranty?
Thanks
MrEnergyCzar
This post may help: http://gm-volt.com/forum/showthread...-Regen-bearing-Noise!!!&p=1375465#post1375465Thank you so much for this post! I just dropped my Volt off at the dealership on Friday because of this whining. I came home and researched it on the internet and thought it was most likely the bearing. The dealership confirmed on Monday. You have answered all my questions except does anyone know what percent of all Volts have had this issue? Is it rising to the level of a recall? (My Volt is a 2012 w/ 38k)
Are there some things that need updating here?Do I need to have the car towed to the dealer?
It shouldn't really be a problem driving it another 18 miles (30km) but you can contact OnStar and have it towed to be safe and minimize any collateral contamination (just plastic debris for the most part). There is no serious damage as long as it's dealt with expeditiously. But since the appearance noise is so sudden and obnoxious to your average Volt owner, that really isn’t a problem.
What if the bearing noise problem persists or returns after repair?
Get your Volt Advisor involved. There's not much chance of a repeat failure, providing the bearing was properly replaced, as in the technician carefully followed the published process for it's removal and installation. If for whatever reason they do not (e.g. didn’t have the correct tools, or didn’t use them correctly, didn’t follow the detailed instructions for R&R or measuring the bearing race for proper alignment after it's installed etc. etc.) then the repair might NOT be a success, especially if the noise does not alleviate (or returns after a short period of time). If the dealer tech had some sort of trouble replacing the bearing they MAY need to replace the complete rotor (comes with the bearing) or even the drive unit assembly in order to remedy the issue.
What causes the bearing to fail?
Damage to the bearing race during final assembly of the drive unit.
Why is the whining sound louder during regenerative braking?
The noise is more pronounced during regen because the magnetic fields created between the rotor and stator windings during regen are quite strong which creates certain thrust forces that actually move with the active poles involved, and therefore placing fluctuating loads on the bearing. So technically the noise it ALWAYS there but merely becomes more pronounced under these conditions.
Does the cage collapse the same as the plastic cage? I can't really imagine that happening, so I'm trying to picture what is the actual failure, and how is the noise generated?Most all cases of 2nd failure have been attributed to issues created during the service procedure. Most notably not using the proper tools (or not using them as outlined) or possibly the failure to properly clean debris/contamination created from the initial bearing failure and the recommended use the GM transmission flushing equipment afterwards. In most cases the 2nd failure results in a replacement of either the rotor assembly or the entire drive unit.
WOT
As far as I know, they have all been repaired under warranty. So, IDK.how much is it, if the volt is not under warranty?
