1 - 15 of 15 Posts
I took my 2013 Volt to the dealer (Norman Frede Chevrolet in Clear Lake, Texas) for a battery replacement and coolant change (5 year from manufacturing date) last week.
Today I noticed the rear cargo cover would not close all the way. I found several problems, and uncovered a few more when I removed the whole plastic 'tub' that holds the EVSE and air compressor.
The problems found were:
1. there are two tabs in the rear center of the plastic piece under the cargo cover (which holds EVSE, air compressor, etc) These are supposed to fit into a corresponding slot at the rear of the car under the tailgate latch, and there are four 10mm nuts in the corners of the plastic piece. The mechanic had not inserted these tabs into the slot, instead the tabs were resting on top of the slot so the cargo cover would not close all the way and lay flat (no picture of this.)
2. the steel plate that mates with the magnet in the cargo cover underside had come off, and was stuck to the magnet. I can fix this with some 5-minute epoxy. The magnet is also loose (a potential rattle) so I will epoxy that in place at the same time.
3. The battery vent hose was left unconnected. However when I push it into the hole in the battery, there is nothing locking it in place, it can easily slide back out. Update: there IS a very slight 'click' when pushed in all the way, and I secured the hose to the side of the battery with some tape as a backup.
Also, if you follow the procedure in the maintenance manual ("Battery Replacement) exactly, it says to disconnect this hose when removing the old battery, but does NOT say to re-connect the hose when installing the new battery (it is shown in the diagram however).
Auto part Technology Electronic device Engine Vehicle
4. The mechanic left his 13mm wrench inside the car! This looks like a safety hazard if it should contact the battery terminals bouncing around in there:
Vehicle Car Auto part Subcompact car Family car
3. There is a hose left unconnected. There is what looks like a blower motor next to it. Does anyone know where this should be connected?
Just plug it back into the hole of the 12V AGM where it belongs. It is designed to vent of any gasses that a properly working AGM won't produce anyway...
Cool! Free wrench!:cool:
I bought the 12V AGM battery from my Chevy dealer and replaced the battery myself (2012 Volt, almost 6 years old). The OP experience reminded me why I try to avoid dealer service departments if I can do the job myself. I did, however, have the dealer do some other more complex preventive maintenance later on, but they did not seem to mangle anything.
A little bit of 5 minute epoxy on the magnetic latch and it's all back together like it should be now (without wrench inside). The cargo cover closes with a satisfying 'click' and lays perfectly flat.
I just got my Volt two weeks ago so I've not had time to learn all the nitty gritty details. What's that ducted fan for (to the right of the battery)? Main battery? Cabin air circulation?
Don't have a visual reference and too lazy to go look at mine, but I believe that fan would be to cool the DC to DC inverter for the 12V battery charging system. It may also be used to cool the amp for the subwoofer if you have the Bose upgrade.
I don't know for sure either, but it does look to me like the duct goes right under the inverter. Although the blower seems quite large for that job, so there might be more to the story.
Yes, this blower is to cool the 14VDC APM. I have a base Gen1 Volt w/o the amp. If you want to find out how important this blower really is, just leave it unplugged on a hot day and the APM will shut itself down when it gets too warm in order to protect itself...been there and done that!:eek:
As a technician myself (Dodge) I can see both sides of this.
One the one hand is doing the job right. In a perfect world you are aptly compensated financially and with an abundance of time to do the job comfortably, as a surgeon would be. You read the procedures, perform the task and then check your work. Everything as it was, give it a spit shine, send it on it's way and move on to the next job.
But this is not a perfect world. The manufacturers present unrealistic flat rate times to perform procedures that clearly will take more time than you (the technician) are being paid. So you rush to try to meet the time and not lose money. Then the dealership management, firmly believing more is better, over staffs the shop with technicians, and overbooks the schedule. So you end up with more work than you can possibly do in a day and a hoard of howling service writers looking for their cars to get done first.
And as a plot twist, the service manager, knowing he'll make more money by getting lower paid techs and lube jockeys to do advanced work, will cram as much work through quick lube and the younger techs as possible.
I'm a careful worker, and I've been forced into mistakes myself by not being firm enough with the service writers and fellow techs. Get pulled off a car to work on a waiter, or have a fellow tech distract you while you're in the middle of something can end in an error.
The game is rigged as so, and the deck is stacked against both you, the customer, and the technician trying to make a living providing service.
As far as finding the 13mm wrench inside, I guess you should be glad this guy was your mechanic and not your surgeon.
No, because the malpractice claim WOULD BE SETTLED for big bucks and the removal of the instrument will be "on the house"...compared to this auto "repair" which will be effectively ignored by the dealership and the amount is too small to sue over...:rolleyes:
Discussion Starter · #15 ·
I wouldn't be profitable as an auto mechanic, I like to do a job right no matter how long it takes. Spent about half yesterday (off and on) getting everything exactly right again. It was one of those nice mornings that being retired, I could take my time. While I was at it I replaced the engine air filter and cabin air filter. Got a good deal at Autozone, $22 for both.
1 - 15 of 15 Posts
