I've switched CS mode several times, while entering into my neighborhood, and was able to keep the ICE from starting with some smooth and easy driving (~0.3 miles).The car tries pretty hard to keep the engine off while stopped - I would expect it to go go thru most of the buffer before allowing the engine to start.
WOT has stated there is no on the fly SOC window widening.If the car is programmed to maintain available kw-hrs then the max % SOC will climb as total battery kw-hrs declines over the years. Has anyone seen that this is happening?
KNS
I asked a volt engineer about this exact thing and he told me the battery does not do this.If the car is programmed to maintain available kw-hrs then the max % SOC will climb as total battery kw-hrs declines over the years. Has anyone seen that this is happening?
KNS
The kWh Used display is not a meter and it's not a measurement. It's an approximation estimate based on assumptions the car is making.I wonder if a more accurate power meter could be used? The built in meter does account for regen braking by subtracting it off, so this is good.
I guess that the Volt extends the SOC window over time to avoid Leaf effect.I am really surprised, if that data is correct from Torque, this means 68.6% SOC window, not 65%. Maybe the buffer floated lower before the engine kicked in, I don't know. It did switch to gas, but the engine did not kick in for a little bit longer.
WOT and others at GM have stated there is no on-the-fly SOC window widening.I guess that the Volt extends the SOC window over time to avoid Leaf effect.
I don't see evidence to support this, I think it is a meter and directly measuring current in and out of the battery. Maybe I am wrong, but my guess is it is counting coulombs (integrating current) into and out of the battery using a hall effect sensor(s), this way it can easily account for energy added via regen braking, etc. This is a pretty standard way to meter Li-ion battery SOC, calibrated to Voltage at full charge and discharge. The current counting should be very consistent if the sensors are accurate, and I have noticed that the kWh used display in the center is fairly consisitent.The kWh Used display is not a meter and it's not a measurement. It's an approximation estimate based on assumptions the car is making.
The leaf effect happens also Norway and here in Finland, but not as drastic as on some hotter climates. With leaf you are degenerating from day one, but with Volt it's suspiciously level curve. If it smells fish and looks fish, it's most likely a half blind parrot.WOT and others at GM have stated there is no on-the-fly SOC window widening.
The "Leaf Effect" is due to Nissan not wanting a liquid cooled battery TMS like the Volt.
Well, I know for a fact that my car hasn't opened the window significantly yet, and we all know that Ari's car hasn't - because he just posted absolute state of charge information from Torque which matches the original new specification (and I have a meter rigged up in my DashDAQ that also uses the absolute SoC values.)The leaf effect happens also Norway and here in Finland, but not as drastic as on some hotter climates. With leaf you are degenerating from day one, but with Volt it's suspiciously level curve. If it smells fish and looks fish, it's most likely a half blind parrot.
