On the Config Menu, Display Settings, there is a sub-folder named "Rear View Camera." It contains 2 options: One toggles the camera on/off. This works fine, takes immediate effect and does not require a shut down/restart.
The second option is titled "Symbols" and appears to also be an on/off toggle. But it has no effect on the camera display either immediately or with a shutdown/restart. No symbols or graphics appear on the camera display.
I can find no documentation on this item in the manual that came with the car, nor in a couple of other editions that I found online. There are pictures posted that show the Volt camera display with a ladder-like graphic and cones which I assume are the "symbols" it refers to.
If it is a valid option, I would like to enable it. Is this situation that could be remedied by a cold reboot of the car?
I would appreciate any info or suggestions.
