1 - 6 of 6 Posts
So it seems my backup camera lens seal broke, and it has moisture in it. Picture is blurry and does not dry out. Dealer wants $495 to replace it.
Do I have cheaper options? Could I just replace the lens or do I really need to replace the entire thing? I asked the dealer if I had them do it, would I get the backup lines on the new unit, and they did not know. Mine is a 2014, but I believe the 2015 has lines. Probably not. But for $495, I wonder if aftermarket would be cheaper?
Thoughts?
It is possible to DIY. I don't think the lens is replaceable. You do the whole camera. You can use the GM part or aftermarket with more wiring challenges. I think the GM part is about $100-110, IIRC.
The kicker is you have to remove the rear bumper cover, which is quite a process. Once that is done, it is pretty simple, just plug it in. There are a lot of threads about it here if you search. Not sure about the grid lines. I think that would be a feature of the head unit rather than in the camera hardware. Some aftermarket cameras might possibly have grid lines in the camera hardware.
The ELR camera was terrible. Especially at night. The CT6 cameras are much more clear.
Maybe GM has an updated unit?
I had a 2014 without the lines. My 2017 has the lines and they make a huge difference. Get lines if you can.
It's not too difficult to replace. You can pick up a replacement for right around $100.
You have to pull the rear bumper half way off, then it's just 2 screws that hold the camera in and a single plug.
My camera had an internal short so it would blow the fuse every time I put it in reverse. Unfortunately there also seems to be a bad connection, because there is still no picture with the new camera and I don't have time to mess with it.
If all goes smoothly, you can do it in less than an hour.
Maybe try a hair dryer on the current lens first? Then seal the edges if that works.
I added my own (see signature) and didn't even have to remove the bumper cover (I tried but couldn't get it to release so I gave up and figured a way around it).
1 - 6 of 6 Posts
