1 - 8 of 8 Posts
My right shoulder is chronically a little bit problematic. It's been worse since I bought the Volt, and I eventually figured out the problem is the arm rest in the center console-- leaning on it aggravates my shoulder. Unfortunately, with the armrest down it's impossible for me not to do that.
I've started flipping it up while I drive and that helps, but it means that I have to do it every time I get in the car, and if I stop quickly it smashes into the back of my arm.
Anyone aware of a lower-profile replacement? Or, thoughts on disassembling it and removing most of the padding then making a new cover?
Have you tried raising up the driver's seat?
Along the same line of thought, you could put a seat cushion on your seat as another way of raising the seating surface.
I don't know if it is easy to remove the console lid completely, but you could do that for a month or so until you lose the habit of resting on it.
Discussion Starter · #7 ·
Thanks for the responses!
No, I actually hadn't thought of raising the seat. I'd completely forgotten it was possible to do it. That will be my first attempted mitigation.
I do drive with both hands on the wheel, at 8 and 4. The 4 position leaves my arm on the armrest.
The car was comfortable when I test drove it, but I was buying it anyway unless it was horrifically uncomfortable because it was precisely the right car for me in other ways. I wouldn't have spotted this issue in a brief test drive... it only shows up over days or weeks of spending two hours or more in the car every day.
Did you not ensure the car was comfortable before you bought it? That's my first criteria even before the test drive starts.
I'm 70+ and have driven tons of new cars over the years and I must admit, I've never had a 'test drive' long enough to ensure I was 100% comfortable with everything in ANY car I've bought - That would take at least a week and a thousand miles
Part of adjusting to any brand new car is finding out what you're really comfortable with and what you're not . . . . and then, what to do about it. That thousand mile test drive would really help!!
Don
1 - 8 of 8 Posts
