1 - 20 of 21 Posts
My 2013 has 27,000 miles now. I charge both at work and at home as i have a long commute (70 miles) whrn the ICE turns on the KWH meter used to almost always read 10.4KWH used. Now it is pretty consistantly 10.3 (small but very repeatable change). I live in southern california and the temps are not a problem (76F today) anyone else seeong a drop in capacity?
A 1% drop in capacity after 27000 miles? At that rate, you will only have a little over 90% left after 250,000.
It's probably not fair to compare since I'm only at 13K, but I've never seen the engine come on at 10.3 used. I usually show 10.5, sometimes 10.4. Haven't really found a way to predict which it will be..
After 25,000 miles (about 21,000 electric), I've noticed no total range change. I do notice that the KWH used goes up during the spring/ summer and goes down during the fall/ winter so the temp has a big effect. If the battery is slightly colder you'll use less total KWH of the battery or a smaller percentage of 16 KWH... it also may depend if the car was just finishing charging just before you drove, you'd use the max battery amount that way....
MrEnergyCzar
I've seen the switch to CS mode at even 10.2kWh, sometimes 10.4 and I've seen it as high as 10.8 during the spring. I'm at 7800+ miles so far on my 2013.
My volt is 16 months old and I also have a long commute to work ( 109 miles one way) and charge at least twice per day. My volt used to show 10kw used now it's consistently 9.8kw. My volt is a 2012 , 16 months old with 91,944 miles on it in OH. I haven't seen any change in miles I can achieve on the battery.
Sparkie OH on Voltstats.net
P.S. Just replaced right front wheel bearing which is not covered under the powertrain warranty! $388 ouch!
winranger3 - are you setup on Voltstats.net? If not, that high miler should be out there. You would have the highest mileage of all the volts registered.
Great information from a high-miler. You must be saving quite a bit on gas costs. What was your prior car for the epic commute?
winranger3 - are you setup on Voltstats.net? If not, that high miler should be out there. You would have the highest mileage of all the volts registered.QUOTE]
Yes, he's "Sparkie" in Ohio, and he us #1 on the mileage chart.
I use to brag/whine about my old commute of 92 miles each way when I worked as an IT contractor in the late 1990s. But this guy is epic!!
.2% ? Heck, that could be due to the wheel bearing you replaced.
Don't be afraid to post some of your high mileage experiences with the Volt. Anything significant, or all good til the wheel bearing?
all us low-mileage slackers want to know!
I'm a little concerned you had to pay for the bearing. I've had two wheel bearings replaced in a Tahoe within the last 2 years and it was always covered under powertrain because its on a drive axle.
As far as kwh used, those in a climate with big swings will attest to big variation in that number. Personally I've seen .5kwh difference due to charge depletion rate and temp. The faster the depletion rate on your drive cycle, the lower that number gets. But my norm is 10.4kwh. Is your foot getting heavy?
Banned
Shouldn't that be covered under the 36 months bumper to bumper warranty?
My volt is 16 months old My volt is a 2012 , 16 months old with 91,944 miles on it in OH. I haven't seen any change in miles I can achieve on the battery.
Isn't that a short life for a wheel bearing?
Francois
B2653
So, tell us, how much $$ have you saved over that 16 month period?
Per GMPartsDirect a front hub/bearing for a 2011-2012 Volt is $100.74. Plus freight, of course, but that's not the price that a Dealership would pay anyhow. Seems excessive that a shop charged you That much "extra" to swap out a cartridge wheel bearing. Couldn't possibly take more than about an hour of shop time. For Something close to $280 of Labor? Ouch!
That would be 36 months OR 36000 miles. And he is nearly 3x past 36000 miles.
In fact he is fast approaching the battery and powertrain warranty limits (100K miles).
MrEnergyCzar
I have a theory on this. As my 2012 will give me ~10.2 KWh in the fall/spring but only ~9.8 KWh (or less) in the summer/winter, I think the display only shows what the driver used for propulsion/climate, etc. I think the rest is being used by the TMS so they do not include this in the figure as the driver did not/could not affect this energy usage.
Can someone in the know confirm... WOT???
Senior Member
109 miles one way????
Why don't you move closer?
I am not ashamed to say that my one way commute is 2.5 miles!!!! :)
C-5277
I have 18,50 miles on my Volt. No loss of capacity. No loss of range. No loss of anything. Almost Zero brake wear. I still have the original oil. Only maintenance I have needed was to rotate the tires and refill the washer fluid.
1 - 20 of 21 Posts
