1 - 13 of 13 Posts
I was swapping out my all seasons for my winters today and broke two wheel studs on the same wheel. Has anyone else had this happen? It happened while I was using my torque wrench set to 100 ft-lbs. I'm taking it to the dealer tomorrow, I'm hoping it will be covered under warranty, but I'm not too optimistic
https://ibb.co/n4W88G
yuck, yes, I too doubt they will cover that. Perhaps your torque wrench calibration is off? Was there any oil, grease, lube on the studs? That could cause a false (lower) reading.
When was the last time you calibrated your torque wrench?
When was the last time your calibrated your torque wrench?
Torque wrench is less than a year old (used it twice). It worked fine on the other 3 wheels and then checked the other lugs with my older manual lever type wrench. All at 100 ft-lbs. The same for my other vehicle.
Never seen this before, are you sure you didn't let the Hulk torque the lugs? lol
2014 Cadillac ELR
Was this removing or installing the nuts with the torque wrench?
I sprayed the hub to keep wheel from sticking to it.
To prevent galvanic rusting, I use an anti-seize paste on the back of my aluminum wheels where they meet the steel hub. I carefully apply a thin layer using a cotton swab. Just enough to put a "barely there" film on the surface. I don't want it flying out as the wheel spins. I also don't want it on my lug studs.
Bolt EV wheel anti-sieze tubw and applicator.jpg Bolt EV wheel anti-seize application.jpg
Discussion Starter · #10 ·
View attachment 142961 View attachment 142953
Good idea Steverino. Took my volt to the dealer today. $140 in labour to replace the wheel studs. $6 for the 2 studs.
Next time OP, or anyone else gets studs that feel stuck and/or rubbery as you twist them with excess torque, take a timeout and find someone with a good impact gun. Impact guns are more gentle on studs than a hand wrench.
And yes, always use antiseize. People that say not to are probably antivaxers.
2013 Volt
Here's a pretty good demonstration video of the problem.
Since you don't know how many of the other studs were stretched beyond their yield points, it would probably be a good idea to replace all the studs on all the hubs that were sprayed. Those tiny studs can be pretty important when coming down a mountain switchback.
2014 Cadillac ELR
To be clear: anti seize on the HUB, definitely not on the LUGs! Using a lubricant on threaded fasteners increases the applied torque by approx 60%. Therefore, if you use anti-seize/oil/grease/whatever on the threads, and torque to indicated 100ft-lbs, your actual fastener torque is 160ft-lbs. Install wheel nuts DRY, just like the manual says.
I agree that leverage force has broken those lugs. It can be tough to use all your force in a rotational direction instead of levering down as you attempt to break the nut free. I highly recommend buying a good electric impact if you are going to do seasonal wheel swaps. I have a big compressor and full air tools, but still use the electric impact when swapping wheels.
1 - 13 of 13 Posts
