Anybody experience this charging fault? "!" red flash and 3 green blink twice
This morning I found my car with no charging light in dashboard, and the charger had up left solid green light and right "!" red flashing. Below, 3 green led flash 2 times then one green light, 3 green 2 times blink again and so on.
After some tests I found out that the problem is the outlet in the house, the third one that fail in time. Weird is that outlet is working for everything else except charging car, and weirder the outles beside this one that is on the same circuit work just fine. I read in the manual that outlet could wear it time and became unuseful for charging the car. I try to change the outlet, the wires looks ok, safety(16AMP) for 220V socket is good as long as other outlets work for charging, so I don't know why after ~ 1 year of use the outlet fail only for charging the car. Maybe the EVSE detect some fault but I don't know how to fix it.
I will make a separate circuit just for one outlet for charging, but for the faulty outlets I don't know what the charging for long period do to them as they work for everithinh except charging.
A day before I wash the car and at that night was -7 degres, I don't know if has something to do with it...maybe just coincidence
