1 - 3 of 3 Posts
the underbody tray just forward of the rear wheels collects an awful lot of sand and pebbles? If you give it a tap from the bottom there's a lot of debris in there. I tried removing as much as I could by hand. Guess I've been driving through a lot of construction or something lately.
Anybody ever experienced this?
Gen2 2018
Yep. If you change your wheels, for snow tires, you'll see right into that under tray and all that gravel in there. Of if you install a tow hitch, you have to lower the back of that under tray and you'll again see all that gravel. I take a hose and blast all that gravel out in the Spring, when I change out my snow tires.
Gen2 2018
That's a good idea. I'm just about ready to switch over to winter tires so I'll be sure to hose it out then. Thanks!
1 - 3 of 3 Posts
