So my Volt's left tail light always gathered water, sometimes up to half a centimeter or so of a little mini-lake, and fogged up. The pooling stopped when I drilled a tiny 1/16" hole on the bottom of the housing to let the water drain today. But in doing that I peeked in and see that the plastic actually warped, I assume from heat, I assume from some sort of electric short! Oddly the tail light and brake light work perfectly.
Thoughts on what caused this without damaging the blinker or shorting the fuse? Pic below.
