1 - 20 of 33 Posts
Sounds like Honda is using the full 6.6KWh Level 2 charging. GM should have done that with the Volt.
Huh. Someone finally made a serious competitor for the Volt. (Though it sounds like the engine comes on when floored on the Clarity PHEV.) It only took seven years...
It'll be interesting to see how this plays out, whether it takes some Volt sales or whether sales of both go up as folks figure out what they've been missing.
P.S. Honda says it comes with power memory seats, too... :p
More competition, the better. It's the only way to move this tech forward.
Nice looking. If it has an EV range of 47 and gets between 40-44 mpg (assuming in CS mode), how small is the fuel tank to only allow for 340 miles total range?
By comparison, my Volt routinely gets 420 miles on a full tank and charge.
More data is needed. But at first glance, the first EREV competition to the Volt is coming. But if it's 'combined' power like most plug-ins, the Volt will probably still be the superior driver's car.
Ha ha. I get 110 EV miles in my Volt but not regularly... often 68 EV miles, yeah, my GOM's range is 600+ miles at times, but most times it is about 540 miles total range after charging.
Maybe Honda will advertise their EREV so GM can see how that's done?
plate says fuelcell
I believe the Clarity line now comes in 3 versions: BEV, fuel cell, and now PHEV/EREV. But they all have the same body, just like Ford Fusion's regular, hybrid, and Energi versions.
Not a chance (for GM that is). VW spent years advertising their product line as the "only" option if you wanted to go from entry level to high MPG yet the Cruze line did just that, including exceeding the VW's product line's high end for efficiency. Not a peep out of GM. The reality is if it isn't a truck or built on a truck chassis then GM doesn't know how to market it.
1 - 20 of 33 Posts
