I ordered the all weather rubber floor mats when I purchased my Volt a year ago. The mats themselves are very high quality and look great. However, the hold down grommets break very easily and were a disappointment on an otherwise great product. I liked the concept of the hold-down hardware, but the execution by the manufacturer was bad. When removing the mats for cleaning, they tend to break - I have not had any luck finding OEM replacement grommets and have been told that the only way to get replacement grommets is to get new mats
This got me searching for a replacement grommet for the mats. I found what looked like an exact replacement with a VW part number 3C0-864-523-9B9 "Bracket" and a 3C0-864-521-9B9 "Cap" which wound up costing only $1.40 per pair from a VW dealer online (www.thevwpartsstore.com). I got the parts and while the look and function is close, they are not an exact match. The center hole on the VW part is too small to slide over the post in the floor. I decided to modify the VW parts to see if I could make them work. Drilling out the VW part somewhat compromises the spring clip function, but it does latch onto the existing post. The new parts appear to be more robust (even after drilling out) than the originals. I'll update this post after I have used the modified parts for a while.
Here is a description of each of the photos:
Original parts on the right, VW parts on the left.
http://www.flickr.com/photos/[email protected]/6995868170/
http://www.flickr.com/photos/[email protected]/7141954159/
1" hole in scrap wood to hold the grommet centered.
http://www.flickr.com/photos/[email protected]/6995868570/
0748 - Grommet in 1" hole, prepared for drilling 1/2" center hole.
http://www.flickr.com/photos/[email protected]/6995866628/
0749 - Hold-down to prevent spinning.
http://www.flickr.com/photos/[email protected]/6995865748/
0750 - Drilling completed.
http://www.flickr.com/photos/[email protected]/7141951923/
0751 - Drilled part, needs cleanup.
http://www.flickr.com/photos/[email protected]/6995864482/
0752 - Completed, cleaned up part.
http://www.flickr.com/photos/[email protected]/7141950315/
0753 - Rear view, completed part.
http://www.flickr.com/photos/[email protected]/7141949387/
0754 - Installed - top is new part, bottom is original. The hole in the mat did need to be trimmed about 1/16" in diameter for the new part to fit.
http://www.flickr.com/photos/[email protected]/6995862102/
