I am a new (to me) Gen I Volt Owner. I charge at home and work and mostly get along just fine with the 120V charging.
I will be travelling with my new job a lot and leaving out of the local airport Sacramento International. Its a nice airport and has free charging in the parking garage and the Daily lot. Nothing in the Economy Lot.
What I don't understand is why on earth would the airport make all the chargers 220 Level II.
Most that park at the airport leave for at least the full day (10 hours) and normally for more than two days.
Even if I had a Tesla S with a 60kw battery on 120 AC charge is 52 hours from depleted. So what I would be gone anyway.
I understand for some the 220 would be needed. Say the southern California meeting and back the same day.
But for most of us the 120 would work fine.
Also while on plugshare I was looking at the comments about the chargers at Sacramento. Mostly you get a bunch of BEV's needing a charge and they go to the airport to charge on one of the free L2 chargers and pay the parking fee. Doesn't make a whole lot of sense to me but hey sometimes you have to get home.
They complain about Volts taking an EV spot and charging for "days". Complaining how there aren't enough spots for EV's. What did they expect at the airport anyway. Everyone is gone, did common sense fly out too.
I would have liked to seen 120 VAC 20 amp plugs on the walls in like a lock box. Really simple. The OP uses his EVSE plugs into the plug that's in the box, puts their EVSE in the box then plugs into their car. Locks the box with a lock and off you go. Fully charged car when you return, your EVSE is safe (relatively) for pretty much every car out there.
The costs would be way lower than 220 systems and you could put in tons of them.
I guess really I don't see why this wasn't a consideration from the beginning considering its an airport and most are gone two or more days.
What about your airport? Did any do it right? Also it seems if I charge my Volt anywhere public BEV's look at you like you have committed a sin because you can run on gas.
