1 - 5 of 5 Posts
I'm really having hard time locating the airbag module or SDM. Can anyone tell me where this module is located?
I really tried to find a post on this forum with that info with no luck.
I looked under the center console (between front seats) but I only found the drive battery master disconnect.
It's a 2013 Chevy Volt
Please help
Thanks in advance
Please help
Thanks in advance
Did you ever locate the SDM and how did you get it out if you did? Looking to pull my as well
I did.
You have to remove the whole center console. It's under it.
I didn't see it because I didn't remove the whole thing. But if you remove it all you'll see it there.
I did.
One more question, when you installed the reset SDM module did your "Service Airbag" light go out on its own? or did you have to get a OBD scanner to erase.
1 - 5 of 5 Posts
