So the air dams under our Volts often scrape pavement when the road is uneven (grade changes, speed bumps, construction, etc.), slowly damaging the dams. I started to wonder why the dam is one seemingly monolithic piece of rubber. What if the air dam had a different material and form to make it a bit more resilient?
I guess I need to figure out what the air dam has to do, first: It has to work as an air dam, of course, pushing along air. It needs resistance from damage from both scrapes and impacts - some sort of balance of hard and soft (I'm sure a materials scientist would know the right terms!). And it'd need a lot of flexibility, but it needs to "remember" its original shape well. Optimally, it should lose function slowly - something that gets worn down more like a wiper blade than the tears I've seen in some other threads. Anything I missed?
My first concept was something brush-like (i.e. a dense forest of soft bristles pointing downwards, like a broom). But there'd need to be some care chosen to find a material that won't permanently deform if the the bristles get bent on something like a parking block, and then the car is parked there for a month or so. I don't think the dam has to be perfectly smooth, but I'm not sure. (And the current air dam doesn't stay very smooth for that long, anyway!)
Any other ideas?
Any other ideas?
