GM has refined the Volt in the wind tunnel to increase efficiency at highway speeds. All of the renderings so far still show side mirrors, which act like air brakes. Given that the wholesale cost & miniscule size of low-lux, waterproof cameras and simple LCD screens are <$100 each, I can't see why we still need to have more expensive, conventional motorized mirror systems. Split left/right mirror images can be presented in a LCD screen mounted at the top of the dash (like a Lincoln MKS). When reversing, the center rear camera would replace the left/right split view. The cameras can be located at the top trailing edge of the front wheel flare or gill vents to minimize drag. An optional upgrade could use software to merge the view of the rear center camera like the Infiniti EX35 to provide a seamless, 180 degree rear view. This screen would be dedicated for cameras only. A separate lower screen could show electrical system status and an optional touch screen upgrade could be used for entertainment upgrades.
We could also eliminate door handles, like the CTS coupe concept. If the solenoid buttons are too expensive, GM could put "D" shaped pulls within the cutaway.
Isn't it interesting that the most aerodynamic EV, the Aptera, already has these two features?
