My daily commute is really short, and, as a result, I use only around 1.2 kWh of power maximum a day from the high voltage battery on my Volt. The power in the area I live comes from coal plants, and I've been looking for a way to reduce the emissions footprint of my volt (regardless of increased cost per mile). Rooftop solar isn't an option for me, as I currently live in an apartment.
As it stands, I believe I can make a 400 W rated solar charging system that can be stored inside the Volt and deployed on top of it when parked. This would allow me to collect power while at work during the day.
The system would consist of the following:
4x 100W rated semi-flexible solar panels
1x P30L PWM solar panel regulator
2x 100Ah 12V deep cycle batteries (in parallel)
1x 2000W 12V DC to AC inverter
Total system cost is around the $1000 mark, though that can vary a bit depending on the specific equipment used.
On a normal day, the system should get around 1 kW into the deep cycle batteries, accounting for some losses.
The batteries would be discharged about halfway through the DC to AC inverter to power the portable EVSE that came with the Volt running at the 8A setting. A 2000W inverter should be able to handle the ~960W load the EVSE takes.
At a 50% depth of discharge, the deep cycle batteries shouldn't be too damaged. I figure that even with the losses from the EVSE and inverter, this should still handle at least 75% of my Volt's daily power needs.
The batteries don't add much to the cost, and they allow for the use of many fewer solar panels than would be required to run the Volt's charger directly.
There are two potential issues that are keeping me from immediately proceeding with this plan:
1. The EVSE that comes with the Volt is fairly picky about what it's plugged in to, and most inverters use modified sine waves, not pure sine waves. Pure sine wave inverters are more expensive.
2. The manual highly stresses the need for proper grounding when charging. It is possible that a temporary grounding solution for the inverters might not be good enough.
My questions, particularly with anyone who has an off-grid solar charging system for their Volt, are as follows:
1. Has anyone used a modified sine wave inverter with their Volt charger, and, if so, do you have recommendations?
2. How hard would it be to ground a portable inverter to make it suitable for charging a Volt?
3. Are there any other potential issues with the system that you can think of (besides the economic aspects)?
EDIT: Corrected instance where I said 400 kW when I meant 400 W, thanks for catching that.
EDIT: I do NOT need an amount of solar panels with output sufficient to run the EVSE on its own. Using a battery system to buffer the input from a smaller set of solar panels over a longer period of time is the whole point. You're not going to fit a 1 kW+ solar array on the top of a Volt (not without space-grade solar cells in any case).
