There should be a charge port light that comes on when the door is opened. It's hard to put the plug in at night unless you use a flashlight, putting a couple of LEDs next to the charge port would fix the problem.
It is a "dealer installed" option for the Gen 2 Volt. So it is easy to add after the fact.Wish I had bough the lighted charge port on the volt. Also would like it as an option on the bolt, but it is not.
Not sure about everyone else's but I have that option and the light comes on after you've plugged in the car, not when you open the charge door when you need it. Weird.It is a "dealer installed" option for the Gen 2 Volt. So it is easy to add after the fact.Wish I had bough the lighted charge port on the volt. Also would like it as an option on the bolt, but it is not.
It should come on when you open the charge door if you have just gotten out of the car. Are you coming back later to plug it in? In this case the car may be asleep and not aware of the charge door being open. Pulling one of the door handles, even if locked, will wake the car and turn on the charge port light.Not sure about everyone else's but I have that option and the light comes on after you've plugged in the car, not when you open the charge door when you need it. Weird.
Over the years....we have had to plug in a LOT of things in the dark....and this is just one moreThere should be a charge port light that comes on when the door is opened. It's hard to put the plug in at night unless you use a flashlight, putting a couple of LEDs next to the charge port would fix the problem.
Check out this Instructables DIY illuminated charging port: http://gm-volt.com/forum/showthread....-Charging-PortThere should be a charge port light that comes on when the door is opened. It's hard to put the plug in at night unless you use a flashlight, putting a couple of LEDs next to the charge port would fix the problem.
Thanks! I'll do that. I'm surprised that opening the change door doesn't wake it up enough to turn on the light, but at least there is a work around. Cheers.It should come on when you open the charge door if you have just gotten out of the car. Are you coming back later to plug it in? In this case the car may be asleep and not aware of the charge door being open. Pulling one of the door handles, even if locked, will wake the car and turn on the charge port light.
Pulling on the door handle does not turn the charge port light on.Thanks! I'll do that. I'm surprised that opening the change door doesn't wake it up enough to turn on the light, but at least there is a work around. Cheers.
I have one that does have an LED in the head of the handle. It's the original round, 240V, hang on the wall, "Voltec" EVSE. The light is definitely an upscale feature.I wish EV charging stations were available with illuminated J1772 connector. I dont understand why it isn't yet available. No need for an illuminated port on the car. It would also be easier to connect it back on the charging station.
The door handle? As in driver's door handle? Every time the driver's door is opened the charge port light goes on and shines through the crack?Pulling on the door handle does not turn the charge port light on.![]()
See my avatar for an idea of what it looks like in the dark.With the time change I had to mate the charging plug with the socket by feel in pitch dark. If this thread didn't exist I prob. would have started my first one. My Volt is one month old. The powered lighting systems described in the thread would be ideal but I wanted to address this tonight, for $0, or near zero.
So here's what I came up with. Took ~20 minutes. I had some stick on glow in the dark stuff laying around. Used a compass to mark the circles, Razor blade and scissors to cut it out.
I've some pictures but cant post any with a 0 post count.
Some current glow in the dark materials available perform very well. Some will visibly emit photons many hours after exposure to ambient light. And really that's all I need in a pinch is a few photon (assuming my eyes are at least somewhat night adapted) to help me get the plug alligned.
I'll find out tomorrow night if this has any glow left in the evening.
