I don't think the 3.6KW Gen 2 charger physically fits in the Gen 1, which would be the first impediment to the faster charging. Also the time difference from 3.3 to 3.6 simply won't be that much given the Volt's battery size.Considering exactly zero folks have posted success in dropping the 3.6kW OBCM > 3.3kW OBCM from Gen2 into the Gen1, I predict an equal number of people will have similar success in the future 7.2kW > 3.6kW retrofit into previous generation(s) of the Volt...
The wiring from the charge port to the on-board charger isn't hard to replace as well if you're going to swap the on-board charger itself. Coolant flow, thats a none issue, the computer monitors temp, if it exceeds a certain value it runs the thermal management system. So if charging at a faster rate increases temps then the on-board system will just run more often on its own. The biggest hurdle I believe is going to be software. If the charge rate is limited by software in another module besides the charger then it may present an issue.The wiring from the charging port to the on-board charger and from the charger to the battery pack would need to be up sized to handle the increased amperage. The coolant flow rate to the on-board charger might have to be increased to provide additional cooling capacity. Updating the Volt's software is probably the biggest hurdle.
Totally different, as previously stated physical dimensions were different and 3.3 to 3.6 is not worth the money but for shear convenience 7.2 is way better than 3.6. Countless times I could've made my trips on all electric if the charge rates were higher.Considering exactly zero folks have posted success in dropping the 3.6kW OBCM > 3.3kW OBCM from Gen2 into the Gen1, I predict an equal number of people will have similar success in the future 7.2kW > 3.6kW retrofit into previous generation(s) of the Volt...
Unless gas goes to $10/gallon, I'm guessing the payback would be measured in millions of miles...Taking that into account, what would the payback time be for using less gas and more electricity?
But a French Volt dealer in Quebec has installed a DC QC into newer volts using Spark EV partsConsidering exactly zero folks have posted success in dropping the 3.6kW OBCM > 3.3kW OBCM from Gen2 into the Gen1, I predict an equal number of people will have similar success in the future 7.2kW > 3.6kW retrofit into previous generation(s) of the Volt...
Nothing is impossible (well, almost nothing). But cost and practicality have to be a factor. Would you pay $20K for this upgrade? Obviously not since you'd just buy a new Volt. Heck, what about upgrading the battery? Why not retrofit a Volt with higher energy density batteries as they come available? Not completely impossible, but cost and practicality would negate any possibility.But a French Volt dealer in Quebec has installed a DC QC into newer volts using Spark EV parts
Is this higher charging rate verified/confirmed working on this Volt and is it still on the road or just a one-off experiment?But a French Volt dealer in Quebec has installed a DC QC into newer volts using Spark EV parts
That's not too bad if that's all that is needed for a retrofit into a 2018 or earlier Volt that never came with a 7.2 kw charger in the first place. I'm guessing that may not be the case though.Battery Charger - GM (24285717)
FWIW: Bolt's 7.2kW onboard battery charger currently list at @$700USD at the random part link above so I would expect the Volt's 7.2kW OBCM should be in that ballpark when avail...
The existing Volt charger is like a grand to start with. I can't imaging that the new one will be cheaper.The 7.2kw charging on the 2019 LT is a $750 option. Imagine what it would cost to buy the needed parts over the counter?
