Some issues arise in charging my Volt on my completely off the grid solar system. They amount to "what do you do when the sun goes behind a cloud", more or less. While my home batteries are a bit larger than the ones in the Volt (24kwh for the home), they are not designed for more than C/10 or C/15 levels of drain, and, being lead acid, don't have the round-trip efficiency you'd like to have - especially for cycles more than a few minutes deep (they are pretty good for short cycling). And the more you cycle these, the shorter their calendar lifetime. So of course, that's to be avoided to the extent possible. The 240v EVSE effectively draws about 3.5kw, which is faster than C/10 for my home batteries, and when babying them - less is better.
I have both the 120v and 240v chargers, both Voltec. While the 120v one will let you switch between current draws, it's on the coarse side, and you have to unplug the car to make it respond to the switch. Not an exercise in user-friendliness. At least you can put it on a switched circuit and turn it on and off, leaving it plugged in. Here the charge confirm chirp won't bother anyone, and you can turn off the "theft alert" or whatever that is for the power going off making the car act like a car alarm, so that's a start. Of course, the bigger Voltec doesn't even have a rate control, and as designed, isn't switchable (but of course...when there's an EE in the house).
To make a long story short, while this is less than what I intend to wind up with, I've got a hack that works for the moment. My solar electronics include some Xantrex (now bought by Schneider) charge controllers and inverters, which have a programmable Aux output that can be set to switch on various conditions. I am using one of the outputs to control a few large solid state relays that switch power to the two charger cords I have, and it's working well. You can't quite easily get perfection this way - for example, you can't turn on the relays via one trigger source, but off by another (but you can if you consider driving both of the SS relay inputs with different aux outputs...wired AND logic), but even just using one simple criterion and some timing the Xantrex stuff provides, I've got some thing that is now real usable - and I don't have to get up every few minutes to throw a switch or unplug/switch/plug the car.
I simply set the Aux output to go true when battery voltage was high, up near the "absorb" voltage for my system, and cut off when it got below the "float" voltage. Each trigger on or off has a time delay associated with it to add what amounts to hysteresis to the system so it doesn't "hunt". I'm using a 1 min delay (battery has to be high for over a minute to trip on) and a two minute delay for off - this is to ensure we don't waste too much time just rebooting the EVSE all the time, it takes some seconds to start charging after power is applied.
A picture of this as it sits would give an electrician/code inspector the willes, so I'll abstain till I make it look pretty. For now, all I did was bolt the overrated (480V 40A) relays down to a large aluminum panel (heatsink) and proceed to wire it up, using nice crimp+solder lugs for everything, and a phone type wire over to the solar stuff to drive the optoisolators. I'm switching both halves of the 240, and put in another relay for a separate 120v auto-switched circuit.
In testing with both sun and generator power, using the EVSE in a case where it draws more than either can put out results in a short EVSE on time - 2-4 minutes, then a few minutes for the battery voltage to recover, then a recycle of the process, very slick and neat for a "bang bang" control loop. While you're cycling the house battery a little doing that - it's right at the top of things, the electrolyte that got charged/discharged is still right there and hasn't diffused away yet - over all, if anything, kind of good for a lead acid setup as this sort of microcycle cuts down sulfation. Of course, this cycling means it might take longer to charge the car, but it also means the car can't run down my home batteries if I'm not paying enough attention, and that's more annoying yet.
Either circuit can of course also have other diversion loads wired to it, as I'm putting in switched outlets as well as the hardwired stuff to the car chargers. I have this interesting water distillation unit, hmmm...
I have noticed before that if you unplug and replug a fully charged Volt, it'll go back into some kind of "top off" mode for awhile again. With this cycling, that happens a few more cycles after the car is reporting a full charge, but not many. I doubt it hurts anything, as this mode does draw less power - more like 1kw off the 240 charger when it's happening, and it doesn't go on forever. If anything, I'm squeezing in a little extra for the range games we all play.
I expect not to need this as much this summer, when the new 2.4kw worth of panels get off the ground and up into the sky, but weather hasn't permitted that yet. I am still going to make a fully adaptive charger with the J1772 cable I bought and an EzWebLynx web server/controller I also got, so more control will be possible.
