You're using the Adaptive Cruise Control for the wrong application. Ha ha ha! And you know what? It won't read stop signs and traffic lights either!I finally got to try ACC recently when my car was in the shop. They gave me an '18 (I think) with ACC. It was interesting but scared the crap out of me when I tried it. I set it to 65 on the highway. Was working fine until I got to a curve where the speed limit dropped to 35 (for good reason). The Volt sped up and took the curve at 65
No thanks...
LOL I know. I was just caught off guard because when I approached the curve, the person in front of me slowed down so the Volt slowed down (which was good). That person then changed lanes and the Volt (I guess not seeing anyone in front of me) resumed to the preset cruise speed which surprised me a little bit (actually a lotYou're using the Adaptive Cruise Control for the wrong application. Ha ha ha! And you know what? It won't read stop signs and traffic lights either!
Yeah, curves are problematic. In addition to needing to slow on curves, ACC can mess up if the car in front of you takes the curve and the ACC system, pointed in the direction you're going but not in the direction you will go, thinks it has changed lanes and speeds up.LOL I know. I was just caught off guard because when I approached the curve, the person in front of me slowed down so the Volt slowed down (which was good). That person then changed lanes and the Volt (I guess not seeing anyone in front of me) resumed to the preset cruise speed which surprised me a little bit (actually a lot)
It's not possible because there are large parts of the body of the car that are significantly different between ACC and non-ACC Volts because of all the sensors and electronics required. Plus, the control electronics are usually tied to a particular VIN and probably won't work with a non-ACC VIN.Has anyone looked into adding the adaptive feature to the existing cruise control? the cost and feasibility.
Of course it is possible. People have certainly done bigger and bolder. It however may be cheaper and easier to trade in the current car.It's not possible because there are large parts of the body of the car that are significantly different between ACC and non-ACC Volts because of all the sensors and electronics required. Plus, the control electronics are usually tied to a particular VIN and probably won't work with a non-ACC VIN.
So:Of course it is possible. People have certainly done bigger and bolder. It however may be cheaper and easier to trade in the current car.
I just purchased a 2018 Volt premier with the adaptive cruise. Driver confidence package 1 and 2 were a requirement to add ACC. So I guess if you're looking to add it after the fact, you probably have to add those too because it probably requires all the sensors that come with them
