Volt, Electric, and Hybrid Car Acronyms.
- ABS - Antilock Brake System. Prevents the wheels from locking up (ceasing rotation) when a driver steps hard on the brakes and avoids uncontrolled skidding.
- ACC - Automatic Cruise Control. Sometimes called TACC - Traffic Aware Cruise Control
- AER - All-Electric Range mode. The vehicle is driven with motor only (with the combustion engine off), range is the total miles driven electrically before the engine turns on for the first time.
- AGM - Absorbed Glass Mat battery (the 12 volt battery), sometimes called a gel battery. See VRLA battery: http://en.wikipedia.org/wiki/VRLA_battery
- Ah - Amp Hours. The measure of battery capacity as in "1800 mAh".
- APM - Accessory Power Module. A 12V DC-DC converter.
- AT - Automatic Transmission
- AT-PZEV - Advanced Technology Partial Zero Emission Vehicle. For California HOV. Also many upper east coast states adopt CA standards.
- BEV - Battery Electric Vehicle. Example: the Nissan Leaf. No backup power supply, when the battery is empty, the car stops.
- BMS - Battery Management System. Monitors the battery voltages, temps, charging etc.
- BTCPITW - Battery Too Cold, Plug In To Warm. Displays during extremely cold temperatures, when the vehicle will not start until the high voltage battery is warm enough to conduct electricity. Protects the battery. If very cold, but not extreme cold, the car will start but you may see a Propulsion Reduced message until the battery is warmed by normal car operation.
- BURPING - After a full battery charge, disconnecting and reconnecting (after waiting a minute) the charge cord for a bit of extra charging. Unlike a baby, nothing spills on your shoulder.
- CARB - California Air Resources Board. Established 1967 by then-governor Ronald Reagan. A department within the cabinet-level California Environmental Protection Agency. Other states are permitted to follow CARB standards. Establishes standards for low and zero emission vehicles: LEV, ULEV, SULEV, PZEV, AT PZEV, ZEV.
- CAVUTO - Cloddish, Asinine, Vapid, Uninformed, Thick-Headed & Out to lunch. An idiot. As in, “Look at that CAVUTO with his gasoline powered teleprompter”. See http://mediamatters.org/blog/201108230004
- CD - Charge Depleting mode. An operating mode in which the energy storage state-of-charge (SOC) may fluctuate but, on average, decreases while the vehicle is driven.
- CDH - Blended or Charge-Depleting Hybrid mode. An operating mode in which the energy storage SOC decreases, on average, while the vehicle is driven; the engine is used occasionally to support power requests.
- CEL - Check Engine Light. A malfunction indicator light, a.k.a. MIL.
- CHMSL - Center High Mounted Stop Light
- CS - Charge-Sustaining mode. An operating mode in which the energy storage State of Charge may fluctuate but, on average, is maintained at a certain level while the vehicle is driven. This is the common operating mode of commercial Hybrid Electric Vehicles.
- DIC - Driver Information Center (Instrument cluster example where you see your current MPH.)
- DOD - Depth of Discharge. The amount of usable battery available to drive the car : http://nissan-leaf.net/2010/08/04/le...-of-discharge/Also see SOC.
- DRL - Daytime Running Lamps.
- DTC - Diagnostic Trouble Code. A fault code, usually stored in a control unit in the car. If you have a problem with the Volt, press the OnStar button, ask them for the DTC, write them down. This document will tell you what is wrong: http://service.gm.com/gmspo/mode6/pd...iagnostics.pdf
- EDR - Event Data Recorder. A device in some automobiles used to record information related to vehicle crashes or accidents.
- EMM - Engine Maintenance Mode. Runs the engine to keep it in good working condition after approximately six weeks of no or very limited engine operation.
- ERDTBT - Engine Running Due To Battery Temperature. The engine will kick on to power the car while the battery is warmed after a deep freeze. Once the battery is thawed, it takes over and the ICE shuts off. This action appears to be independent of the Outside Temperature Sensor and relies on the battery's own set of temperature sensors.
- ERDTT (also ERDTCT, ERDTLT) - Engine Running Due To Temperature (variations: Engine Running Due To Cold Temperature, Engine Running Due To Low Temperature). Engine Assisted Heating in the owners manual. The engine will kick on for a short time to provide warmth to the cabin's heating system. Depending on Volt model year, this action is triggered by the Outside Temperature Sensor seeing 15°F, or 35°F (MY2013+), 25°F (MY2011/2012). It does not warm the battery, only the cabin.
- EREV - Extended Range Electric Vehicle. An electric vehicle that can continue traveling after the battery is depleted. Example: the Volt. Also see REX.
- ESC - Electronic Stability Control. A computerized sytem to detect and reduce loss of tire traction (skidding).
- EV - Electric Vehicle. A vehicle that is moved by electric motors. The Volt is an EV.
- EVER - Electric Vehicle with Extended Range. Fisker's rearrangement of EREV to distinguish its Karma from the Chevy Volt. A distinction without much of a difference.
- EVSE - Electric Vehicle Supply Equipment. It is the cord handle and related electrical equipment that is plugged into the Volt. Sometimes incorrectly called, "the charger". It is the charging interface between the electrical grid and the car. The battery charger is actually inside the car.
- FCEV - Fuel Cell Electric Vehicle. A type of hydrogen vehicle which uses a fuel cell to produce electricity.
- FFE - Ford Focus Electric or Ford Fusion Energi
- FMM - Fuel Maintenance Mode. FMM will run the Volt engine to use up the old fuel.
- FOX - Fake Outrageous Xanthopsia. See http://en.wikipedia.org/wiki/Yellow_journalism
- Ge - Gallon of gasoline equivalent = 34.02 kWh.
- GPS - Global Positioning System. Used to determine your location, or that of a destination.
- HEV - Hybrid Electric Vehicle. Example: Prius. A gas engined car that gets an occasional acceleration assist from a small electric battery.
- HID - High Intensity Discharge. A type of headlight bulb.
- HOV Lane - High Occupancy Vehicle lane.
- ICE - Internal Combustion Engine. Usually accompanied by Vroooom, vrooooom.
- J1772 - The SAE standard for the electrical connector that plugs into a Volt and other EV's. Sometimes referred to as "JIZZ".
- kW - kiloWatt. A unit of power. Power is the rate at which energy is generated or used.
- kWh - kiloWatt hour. A unit of energy. Energy is a measure of how much fuel is contained within something, or used by something over a specific period of time. The 2011-2012 Volt has a 16kWh battery and uses roughly 65% or 10.5 kWh of it. http://www.energylens.co m/articles/kw-and-kwh (kWh vs kW. Compared to the water pump, kWh is the same type of measurement as gallons, which measure total volume, where as kW relates to gallons per minute, which measures a rate of flow.)
- LATCH - Lower Anchors and Tethers for Children. Not the same as strapping a dog to the car roof. That's a MITT.
- LION - Lithium Ion. A type of rechargeable battery. Used in the Chevy Volt.
- LMO - Lithium manganese oxide. A type of rechargeable battery.
- LOF - Lube Oil and Filter
- LTO - Lithium titanate. A type of rechargeable battery.
- MIL - Malfunction Indicator Light. Also see CEL
- MM - Mountain Mode. This mode maintains a reserve electrical charge of the high voltage battery to provide better grade climbing performance.
- MPGe - Miles per Gallon Equivalent. Miles traveled by expending 33.7 kWh of energy, equal to the energy content of one gallon of gasoline. (source EPA PDF:http://www.epa.gov/carlabel/documents/420f13009.pdf)
- MY - Model Year. example, "MY 2011", or "2016 MY"
- NCA - Lithium nickel cobalt aluminum. A type of rechargeable battery.
- NiCd - Nickel Cadmium. A type of rechargeable battery.
- NiMH - Nickel Metal Hydride. A type of rechargeable battery. It is very similar to the nickel–cadmium cell.
- NiZn - Nickel Zinc. A type of rechargeable battery. Often used in cordless tools.
- NMC - Lithium nickel manganese cobalt. A type of rechargeable battery.
- NVH - Noise, Vibration, Harshness. A rating of the noise and vibration characteristics of vehicles. Part objective, part subjective.
- OBD - On Board Diagnostic
- OP - Original Post(er) of a discussion in an online forum. example, "The OP is correct."
- OTA - Over The Air. Some Volt software updates are downloaded and installed via the OnStar antenna. Otherwise, the car must be taken to the dealer for the update.
- OTS - Outside Temperature Sensor. Located in the the lower air intake on the front, passenger side of the car. Also see ERDTT
- PbA - Lead Acid. A type of rechargeable battery. Invented in 1859, they are the oldest type of rechargeable battery.
- PDI - Pre-Delivery Inspection. PDF here: http://gm-volt.com/forum/attachment....4&d=1316287262
- PHEV - Plug-in Hybrid Electric Vehicle. An HEV with the ability to plug-in its energy storage system to get recharged with electricity from the grid.
- PM - Permanent magnet. Produces a high magnetic field with a low mass, and is stable against the influences which would demagnetize it.
- PRNDL - No, not a high tech potato chip. Park, Reverse, Neutral, Drive, Low gearshift selector.
- PV - Photovoltaic. A method of generating electrical power by converting solar radiation into direct current electricity.
- PZEV - Partial Zero Emission Vehicle.
- R&R - Remove and Replace.
- RAP - Retained Accessory Power. The state the car is in when you turn it off but have not yet opened the door.
- REGEN - Regenerative. Refers to brakes that put electricity back into the battery as the car slows.
- REX - (also rEX) Range Extender (the ICE/Generator combo) See EREV
- RKE - Remote Keyless Entry. A proximity sensor will unlock the car when you get near with the key.
- RVC - Rear Vision Camera. A camera in the rear, with the image displaying in the center console.
- SFC - Specific Fuel Consumption. The ratio of fuel used by an engine to produce a certain force.
- SAE - Society of Aerospace and Automotive Engineers. A standards setting body.
- SOC - State Of Charge. Measures how much useable electricity is left in the battery.
- SOH - Battery State of Health or temperature corrected estimated capacity. Measured in Ah's.
- TACC - Traffic Aware Cruise Control. Sometimes called ACC - Automatic Cruise Control
- TCS - Traction Control System. Helps prevent tires from slipping.
- TOU - Time of Use. Electric rates that are lower during certain times of the day, typically late evening through early morning when there is less demand on power generation.
- TMS - Thermal Management System. Monitors and maintains the battery pack temperature for optimum performance.
- TPMS - Tire Pressure Monitor System. Displays tire pressure on the DIC.
- TPW - Targeted/Tentative Production Week (General Motors).
- UFRPA - Ultrasonic Front and Rear Parking Assist. Provides audible beeps as the car gets closer to an obstacle.
- ULEV - Ultra Low Emission Vehicle. 50 percent cleaner emissions than the current average year's models.
- VIN - Vehicle Identification Number. Your car's manufacturing number.
- Walk Home Dissatisfier - Not really an acronym, but a "Walk home failure mode customer dissatisfier” is classified by GM as either 3 attempts to start the engine ; or 2 successive stalls during operation.
- Wh - Watt Hour. A unit of energy equivalent to one watt (1 W) of power expended for one hour (1 h) of time.
3,600 joules. - YMMV - Your Mileage May Vary. Shorthand for, you may disagree, or your experience may be different than mine
- ZEV - Zero-emission vehicle range. The same as AER; there are no tailpipe emissions when the vehicle is in electric vehicle mode.
