I want to put the EVSE in the car and only have a plug hanging out so I can charge easily from an extension cord. Without hassling with the J1772 cord and plug handle.
Where can I get to the five j1772 wires easiest inside the car?. I'm new to the Volt but have done Plugin conversions of 3 salvage TOyotas, so all I need are the schematics and where to look. I also want to hack into be able to put some solar charge into the HV battery directly. Is there anywhere to get access to the HV terminals of the battery that is outside of the battery pack itself? Like the prius,, I could solar charge the HV battery because once the BMS cover was off, one could tap directly to the HV contactors easy enough.
If this is not the right forum, where are the VOLT hackers? I'd rather find an email reflector for such chats.
thanks
Bob
bruninga at usna dot edu
thanks
Bob
