I'm having some concerns now about the ACC. I noticed that when I'm coming to those Speed Detector Signals on the road, from my far approach, especially when the Speed Detector is in the field of view of the Volt's ACC system, the Speed Displays are way higher than what my speedometer is showing. But when the car is an oblique angle as it approaches the detector, the Speed Detector Signal would display the same speed. And I was driving alone.
For example, the speed limit is 40 mph, and I am going 38 mph, the roadside speed detector would flash rapidly my speed as 55! Then as I approach the roadside speed detector, from about 250 feet away, the displayed speed falls back to 38 mph. This has happened in many many situations, with the worst speed display when the roadside detectors are on the outer curve so that it is in line of sight of the Volt's ACC.
What this means is that the ACC's interference is creating higher speed false reading on RADAR detectors. Am just glad that most traffic police are aiming their guns perpendicular to the cars, or from the back of the cars. There could be instances that some police would be pointing their radar directly on oncoming traffic as they radio the offenders to other patrols waiting up ahead. Or if you're following police with the Volt's ACC on, they might mistake you for approaching them at way higher than the speed limit, as they also have RADAR that points at the back and to the front to measure vehicle speeds of the cars before them and cars following them.
