After doing my oil change I recently noticed that my ABS unit is leaking brake fluid. It seems to be coming from one of the brake lines on top of the unit. I think I can get to it to try and retighten, but there are two quick disconnect lines that go from the master cylinder to the abs module that are in the way. What are these lines? I assume they run brake fluid, between the master cylinder and abs unit? If the lines are removed with the brake system need to be rebled? Photo attached for reference.
