I’ve posted this before but I have more info now and a little more knowledge. First I purchased a non running 2014 Volt with everything dead that had been sitting for almost 2 years. I started my journey of getting the car roadworthy by first replacing the 12 volt AGM battery and figuring out reprogramming the remotes, windows and rear hatch. Once that was done I purchased a Innova 5410 OBD2 to figure out other problems. Codes retrieved are P0D17, P0B3D, P0AFA, P0ABC and P0AOC. Most if not all have something to do with low voltage. I did a scan on the HV battery and cell 1 has 0.0 voltage, Cell 8 has 3.0 and cell 10 has 3.5 volts. The rest all the way thru 96 cells have 3.8 with a few having 3.7. I presume the number one is the problem and how do I go about repairing or diagnosing the issue of it being that one cell? Also the car will not take a charge, on startup the message on the cluster comes up NOT ABLE TO CHARGE. Gas fuel gauge is at half full and battery range is at 0. Thanks for the input.
