I've read a couple of posts about the A/C not using up that much energy. It has not been very hot here yet, and i keep the A/C on 75 with the system in Eco mode, and I still get "-5" on the usage from climate control. What's the real dope?
The energy usage screen will punish you with a -5 rating if you use any climate control beyond the blower, even that will result in a -2.5 rating. Ignore it. The true measure is when you have finished your daily drive and view the pie chart of energy usage, HVAC will probably be 4 - 8 % for AC. This is not bad compared to HVAC electric heat where you can consume upwards of 30% of the battery charge just heating the cabin. If you watch the energy usage on the DIC Classic Enhanced screen, when the Volt is parked and the AC is running with Economy setting, you will see the power used fluctuate from 1 - 3kw. Remember that the Volt always starts out using 0.5kw just sitting in Park when powered on.I've read a couple of posts about the A/C not using up that much energy. It has not been very hot here yet, and i keep the A/C on 75 with the system in Eco mode, and I still get "-5" on the usage from climate control. What's the real dope?
A couple giant pieces of electrical tape can fix thatTrust me when I say I will continue to use AC and heat for comfort. I'm too old to think otherwise. But I agree that it's the information overload that gets you thinking about it.
The seat heater and steering wheel heater are powered by the 12V system. They use 100 - 200 watts. The electric heat coil is powered by the 400V traction battery. The heater coils, there is more than 1, are immersed in coolant. The coolant circulates through the heating and cooling loop. The coils can draw up to 9kw, that is like (7) 1300 watt hair dryers running at once.On the flip side of this, the heater is supposed to take up a lot of battery power, while the seat heaters do not. What is the difference? Each of them works with a coil, inductive heater. The only difference seems like the blower motor.
Not quite. One of them only needs to heat a small surface (about butt and your back) and the other needs to heat the entire cabin.On the flip side of this, the heater is supposed to take up a lot of battery power, while the seat heaters do not. What is the difference? Each of them works with a coil, inductive heater. The only difference seems like the blower motor.
I appreciate that the seat/wheel heaters would use less, but that seems like overkill for the car heater system. I could envision an Eco setting that provides some warm air, without toasting the cabin. And whatever power is drawn from the 12v still has to be replenished from the main battery.The seat heater and steering wheel heater are powered by the 12V system. They use 100 - 200 watts. The electric heat coil is powered by the 400V traction battery. The heater coils, there is more than 1, are immersed in coolant. The coolant circulates through the heating and cooling loop. The coils can draw up to 9kw, that is like (7) 1300 watt hair dryers running at once.
The seat heater and steering wheel heater do use power but it does not even register on the DIC. When the Volt is turned on the 12V system is drawing 500w, at a minimum, all of the time. If you turn on the seat heaters and steering wheel heater the amount of power instantaneously being used does not change on the the display, it is below the threshold on the display. When you turn on the HVAC heat the amount power being used immediately jumps up to 4kw, 6kw or even 9kw.I appreciate that the seat/wheel heaters would use less, but that seems like overkill for the car heater system. I could envision an Eco setting that provides some warm air, without toasting the cabin. And whatever power is drawn from the 12v still has to be replenished from the main battery.
