Interesting, thanks. Makes sense. But can you explain how doubling the distance magnifies the difference? I drive 60 miles (or more) on a charge around town. Equivalent to 120 miles on two charges. On the freeway, I'm going 40 miles on one charge. The difference is just 60 vs 40, no? Little regen, lots of wind resistance, lots of energy to maintain high speed. 60 vs 40 miles per charge or 120 vs 80 mpge. Or is it more complicated than that?
Also, my intuition has always been that driving in L wouldn't make much sense on the freeway, and might actually hurt mileage. Any thoughts about that? I rarely use L anymore and just use the paddle regen on the steering wheel to slow the car.
Yes, MikeBCo has it right, the magnifying effect is based on the familiarity one has with the units. A 40 mile difference between the range at a slow speed and at a fast speed becomes an 80 mile difference when translated into "per fuel unit" numbers, and that, to some, makes it "feel" bigger. A car rated at 15 mpg might see the same range mileage numbers as 17-18 mpg around town, normally 16 on trips like this, and only 13 mpg on this trip. Does a 13-17 mpg variation really "feel" as much as an 88-125 mpg variation?
As for regen levels... remember regen is created when braking, L and D are not driving gears. Your battery’s full charge holds a fixed amount of power. On level terrain, you use that full charge for acceleration and for maintaining speed. Maximum range is achieved by maximizing the portion of the full charge used for maintaining speed. Each time you accelerate, you increase the "acceleration" portion and reduce the "maintaining speed" portion.
Regenerative braking enables you to recapture some energy previously used for acceleration as you slow down, but when you accelerate back up to speed, you use more energy than you just recaptured. The impact of regen creation is that it reduces the "average amount of power" used per acceleration episode. A nice benefit in stop and go traffic. Nevertheless, each slow down/speed back up acceleration episode still increases the portion of the full charge you use for acceleration and reduces the portion you use for maintaining speed (i.e., for achieving range), but not by as much as it would if you had no regenerative brakes.
Seems to me the best choice of regen level to use, whether D or L and/or paddle, is the level that you as driver find best for controlling the speed of your car... you want to develop braking habits that minimize the amount of speed lost when traffic conditions require you to slow down. By doing so, you also minimize the additional quantity of power needed to "accelerate back up to speed." The higher the level of regen you apply (e.g., L vs D), the faster the car slows down, but the actual quantity of regen you create is related to the amount of speed you lose, not to how fast you lose it. The goal should be to minimize, not maximize, the quantity of regen created (minimize the amount of speed loss) in order to maximize the amount of the full charge you can use to maintain your speed (to add range).
Some find "one-pedal" driving in L enables them to develop efficient braking habits (even on the freeway where much of the driving is done using cruise control, where it is the computer, and not the driver, who is control of when the chosen D or L is applied to maintain speed). Others prefer to use D on the highway, and to use L in stop and go traffic and/or when using cruise control while headed downhill.
