From what I understand the Gen 2 Volt when charging on 120 Volt from a normal electric plug has more charging losses than one from a 240 Volt, 3.8 KWH charging rate.
So, with the optional 7.2 KWH charging rate for the 2019 Volt will there be less loss than the 240 Volt 3.8 KWH. If my math theory is correct it should be maybe only 1 KWH loss for an entire charge with the 7.2 rate, and for the 240 and 120 volt charging a 2-3 KWH loss for an entire charge.
Also I would believe that during the cold of winter charging at 7.2 KWH you can preheat with out any loss at all, even with our 2016 Volt with our 3.8KWH charging in winter we still loose a little charge when winter pre heating,as the Volt with the initial pre-heating is using more electric than the 3.8 kwh flow rate of electric charging to preheat the interior etc.
