My "53" electric mile range is less than half what is advertised and I'm only getting 18MPG when the ICE kicks in. What has been the average real world experience for users on the Gen 2 volt? Is this normal?
Welcome to the forum. Given your first two posts, I encourage you to take the Volt you claim to own to the dealer.My "53" electric mile range is less than half what is advertised and I'm only getting 18MPG when the ICE kicks in. What has been the average real world experience for users on the Gen 2 volt? Is this normal?
Please provide some additional information including:
Tire pressure: 36 lbs is recommended but many Volt owners operate with tire pressure 2
Hi I have a new Volt to I looked in the manual and Im probably being dense but where can I set the temp for the ICE to kick in from 35 to 15?
Settings > Vehicle > Climate > Engine Assist Heat > DeferredPlease provide some additional information including:
WOW that was fast thanks so much. BTW love Chicago went to grad school in that neck of the woodsSettings > Vehicle > Climate > Engine Assist Heat > Deferred![]()
The Grapevine is a pretty intense drive for any car. You're getting roughly 50% of the rated EPA range/MPG which is what I experience in an ICE car going through the Grapevine.50% stop and go, 50% freeway. no trailer or excess cargo weight, no load on the roof. slight grade through grapevine but not extreme by any measure. normal speed of traffic in carpool lane without pedal on full throttle. In fact, vehicle would not exceed 75mph during ascent even when pedal was depressed all the way. Fans were running extremely loud. nothing wrong with brakes or calipers. climate control off except for heated front windshield. tire pressure at normal cold pressure rating plus a little. braking is normal
You mention that "climate control is off except for heated front windshield". Having the heated front windshield on is equivalent to being on Comfort mode directed entirely at the windshield (defroster). If the fans were loud, I would expect that you had the desired temp set high and the fan speed set to auto. If this is true, you could be using 6600W per hour just for the climate control. Were your windows really fogging/icing up that bad to need this? Setting climate control to ECO helps reduce power. Use Comfort if it is cold or if the ICE is running as it will use the excess heat from the ICE.50% stop and go, 50% freeway. no trailer or excess cargo weight, no load on the roof. slight grade through grapevine but not extreme by any measure. normal speed of traffic in carpool lane without pedal on full throttle. In fact, vehicle would not exceed 75mph during ascent even when pedal was depressed all the way. Fans were running extremely loud. nothing wrong with brakes or calipers. climate control off except for heated front windshield. tire pressure at normal cold pressure rating plus a little. braking is normal
I drive this section of I5 all the time too. It is very intense of mountain/elevation climb and then also temperature.. Was just a few years back they had to close I5 here due to heavy snow.. When I heard I5 was closed I thought it was going to be up on the OR/CA border but it was in the Grapevine section of I5..The Grapevine is a pretty intense drive for any car. You're getting roughly 50% of the rated EPA range/MPG which is what I experience in an ICE car going through the Grapevine.
For those unaware this is a stretch of road that through several sections ascends several thousand feet of elevation with a median traffic speed of about 70 MPH. It's so severe that there are signs all along the road to turn off air conditioning to avoid overheating.
The back side of the Grapevine drops in elevation so much I could usually pick up 10 miles of EV range in my Volt.
Depending on the section of the Grapevine this is not abnormal at all. This is one of the roads that "Mountain Mode" was designed for (literally) and I would recommend using it to avoid loss of propulsion power and overheating.
