1 - 7 of 7 Posts
The Opel version will use 220V for a charge time that is less than 1/2 of the charge time for the U.S. version at 110V. I would install a 220V line with code required NEMA 6R-20 sockets in my garage to cut the charging time. I hope that the circuitry is designed accordingly, so we can just get an optional cord with the 220V plug instead of the 110V plug.
The projected times to recharge
The projected times to recharge shoulb be 3 hours at 220V and 6 hours at 110V:
If your electric circuit is 15 amperes and the voltage is 110V, then the GM charger should be around 12 amperes (to avoid the breaker to open).
So, 110V * 12amps = 1320 W-h or 1.32 kW-h
Then, to recharge 8 kW-h, the time needed will be 8000/1320 = 6.06 hours
Charge times.
Assuming 15% battery loss, 95% electronics efficiency, and battery fast charge capability for 8 kWHr:
Standard 115V wall socket @15A: 6hrs
Special 115V plug @20A: 4.2 hrs
220 V @20A: 2.2hrs
Three phase 220 V @20A: 1.3 hrs.
Industrial three phase 440 V @20A: 38 min.
EEStor to onboard EEStor: 1 min
Discussion Starter · #7 ·
220V for faster charging
Tom:
Thanks! If one were to use a 220V 1 phase line with NEMA 6R-30 sockets (-.- plug configuration), I can cut charging time down to 2.2 hrs!
3 phase would be even better, but I don't know if the proprietary plug that GM would provide is capable of that. I guess that would require a twist lock connector like a L14: http://www.elect-spec.com/nema_twist.pdf.
Does anyone know whether 220V 3 phase has been previously mentioned?
1 - 7 of 7 Posts
