Specs:
64 x Astroenergy 310w PV panels
32 Solar Edge Optimizers (one feeds two panels)
1 Transformerless Solar Edge SE20KUS-480v 3ph 'Smart + Rapid Shutdown' inverter.
DynoRaxx flat roof ballasted mounting system.
3,802 lbs of 2x8x16 concrete ballast blocks
0.060" heat weld TPO white roof re-surfacing with insulation layer.
Total cost (roofing alone was $38,000) was $31,000+$38,000 = $69,000 including all labor, permits, taxes, mistakes, unnecessary steps, unused material. Cost of solar specific supplies $19,500. Total after Fed incentive = $48,300
Production is theoretical at this point: Per NREL calculator - 30 MWh per year.
But due to our Demand-based TOU which can hit $17.32 per kW, the monetary savings should be close to $10,000 a year.
Would I do it again? No. Our city is extremely incompetent and difficult to deal with.
Will report back with actual December results since it fired up Dec 1, 2017. This is the lowest production month and the panels are optimized for June/July/August when the highest tariffs are in effect. These months could save $1500 each unless the tariffs change.
