1 - 3 of 3 Posts
2018 Volt says fully charged on 110 after only 7+ hours.
Starting with a fully depleted battery, the 2018 Volt will take 18 - 19 hours to fully recharge using a Level 1 EVSE at the default 110V/8 amp setting and 12 - 13 hours at the 110V/12 amp setting. It will take 4.5 hours using a Level 2 EVSE at the maximum 230V/16 amp charging rate.
So I'm guessing that you started with about half of the battery used when you plugged in.
1 - 3 of 3 Posts
