Assuming you are starting with a full battery, yes this is normal. Until there is "headroom" in the battery, regen is very limited to protect the battery.Volt 2018 LT w/34K miles
The regen braking system (column paddle) does not seem to fully engage until after driving for several miles. Is this normal? I don't see any mention of this in the owners manual. Comments appreciated, thanks.
Cold temperatures can also reduce regenerative braking.My regen braking varies according to ICE use... when the engine is on thanks to low temperatures, ICE conditioning or the like, the regen paddle barely works when activated. When I am on all-electric battery power, I have full regen and good braking.
Thanks. This is the likely cause, as the "paddle" braking does return to "normal" stopping effectiveness as I continue to drive.Assuming you are starting with a full battery, yes this is normal. Until there is "headroom" in the battery, regen is very limited to protect the battery.
