1 - 6 of 6 Posts
  • Is it possible to charge the Chevy Volt 2018 with a plug switch like this one
    Font Rectangle Parallel Screenshot Transparency
    with a 15 amperage so that I won't have to plug and unplug the cord every time I have to charge? I can't seem to find a plug switch with a 20 amperage. Thank you.
I don't understand your problem. Leave the changer (EVSE) plugged into the wall and connect it to the car. Remove it from the car when you are done charging.
Putting a cheap, made in China device that likely isn't rated for the current that they are claiming is asking for trouble.
  • Like
Reactions: obermd
Why would you plug and unplug every time? If your EVSE is going to be permanently located, mount it to the provided wall bracket, plug it in and leave it plugged in permanently. If you don’t have the wall bracket you can use zip ties. Even better on my early Volt EVSE I used 3” deck screws through the extended plastic as theft deterrent.
· Administrator
moved to Accessories, Apps, Modifications ...
I'm not understanding the need. Maybe to avoid parasitic draw by the EVSE when it's not plugged into the car?
Anyway, I too would be concerned about the quality of the device handling a continuous load while charging the car. An alternative would be a switch and outlet combo:
White Material property Technology Machine Jewellery
2011 Premium, Nav (added back-up camera! :)
Are you charging at 8A or 12A? I might be a little wary of a "consumer" type switch under a continuous 12A load. As others have asked, what is the need? I have not unplugged my EVSE in several months. If you are wanting to control when it charges, use the car to schedule the start/finish time.
1 - 6 of 6 Posts
