1 - 5 of 5 Posts
So today our 2017 volt had her first major issue.
When we turn on the car, the yellow engine light is on, and if we try to shift to R or D or L, we get "Action required **** to park" and the car does not move.
Calling Onstar, they reported the following codes:
P1E00
U2603 - U2604 - U2605 - U2606 - U2607 - U2608
U2618 - U2619 - U2620 - U2621 - U2622 - U2623 - U2624
I checked the 12V battery voltage , it is at 12.36V
It sounds like a BECM failure (TSB - 18-NA-261) others reported.
My question, is has anyone found a way to get the car moving, or am I going to have to tow it to the dealer...?
Thanks for any suggestions
P1E00
This happened to my dad when driving our 2017 Volt. Had to have the battery module replaced. I believe it needed a tow.
So it would not run yesterday, nor this morning, so we called the tow truck, and as we where about to push it out of the driveway to get it onto the truck, it did start moving for a short while (enough to drive it onto the truck), but it started the gas engine and showed "propulsion reduced".
Anyway, we towed it to the dealer, and we will see what they find...
1 - 5 of 5 Posts
