These were two of the first settings I changed on my 2016 when I got it. First morning I went to leave my house it was still charging and I unplugged and the horn went off. A little disconcerting at 6:30 am when some of the family are still in bed sleeping!
As for the max startup volume, mine works, but I don't like that when you're setting it, it does not display the volume setting number that you see on the DIC when you change the volume with the steering wheel buttons. In other words, I know I want max startup volume set to "14", but all it displays when you go to change the setting is the bar gjm3 mentioned and not the number.
So a little clarification is in order...do you have the settings set right, and it's not behaving correctly, or have you not found where/how to change the settings?
