Hello Everyone,
I purchased my 2017 Volt Premier in May 2017 and fell in love it instantly. In June I received a notice that there was a recall program #N172096420 saying Dealership need to reprogram the hybrid powertrain control module 2 if I was noticing any of these issues. ****Certain 2017 model year Chevrolet Volt vehicles, equipped with an automatic transmission (RPO MKV), may exhibit a condition where the driver notices a “Propulsion Power is Reduced” message in the driver information center. This condition is sometimes accompanied by the diagnostic trouble code P0A7F or a significant decrease in actual electric vehicle range. The driver may also notice the engine running at consistently higher power than normal to propel the vehicle and acceleration is slower than expected****
At the time I wasnt having any issues at all and figured I would have it done when I went in for my first service maintenance. Well 2 months later and mileage at 6503 miles, I was driving home and ran out of Electric and went ICE as I did many times. Normally when using HOLD mode or running on ICE, I only noticed a slight sound of the ICE engine on highways or steep hills. But for whatever reason, I got off my exit and came to the stop sign. When I went to pull out using ICE, the motor revved up and was very loud and I was confused what was happening. With every stop I came to, As soon as I pulled out and hit around 11 mph the ICE would kick on causing alot of noise and actual vibration under the floor board on driver side. I made a appointment hoping this recall would solve the issue. I took my Volt into GM dealership today and explained my issues and was told they would do a software update. I got a call a few hours later saying they we finished and I came to pick up my Volt. I asked if they fixed the loud and revving ICE engine sounds on HOLD and I was told by service manager, the technician could find anything wrong with that but still install the software update. I couldn't how the tech could have thought the vibrations and rattleling of the ICE engine at low speed was normal. As I left to go get in my Volt I notice my Center My Link Infocenter was not coming on when I got in. I started the Volt and still nothing, thinking it might be turned off I tried the center knob and nothing. First off I was shocked the technician wouldn't have noticed this not working after the update. They gave me a loaner and i went back to work for the day. I called at the end of the day and asked if they resolved the issue and they told me no and said they have to order a new radio from GM and it would take 3 days. I never got to drive it of the lot to see if the Volt still had the same issues with ICE when driving on HOLD.
My Questions are:
1# Has anyone had these symptoms of ICE engine kicking on loud and causing vibration at take off at very low speeds with the gas pedal barely been pressed down. If so did this propusion recall solve your issues with it.
2# Has anyone out there have a software update kill the radio/MyLink /NAV /BOSE
Something smells fishy and Im wondering whats going on and should I take my Volt to a Dealership has more Volt experience?
Thanks alot, sorry for this long post
Travis
2017 Volt Premier
My Questions are:
Travis
2017 Volt Premier
