1 - 10 of 10 Posts
Were those tests done in 'Normal' mode . . . . or 'Sport' mode? Sport adds a second electric motor for more torque and power and should give faster acceleration results than 'Normal' mode
Don
Don
I do not believe that is correct. Sport mode simply changes the Volt's response to pressing the accelerator pedal. Sport mode does not change the Volt's maximum power output, traction control, drive mode (1 motor / 2 motor), steering or suspension.
I'm not sure who to believe
https://www.greencarreports.com/new...ertrain-how-it-works-in-electric-hybrid-modes
"Its two electric modes are pretty simple: Either one motor powers the car, or both do.
The two motors themselves, known as Motor A and Motor B, are the same diameter but differ in their construction."
Before I bought the car, I watched a long video (nearly an hour) of a GM engineer explaining how the new Voltec drive system operated and how it differed from the Gen 1 and he said the same thing - One motor for 'Normal' and both motors for 'Sport'
Don
Don
I refer to the following article on the Gen 1 and Gen 2 Volt drive trains. https://gm-volt.com/2015/02/20/gen-2-volt-transmission-operating-modes-explained/
For the Gen 2 Volt, Charge Depletion Mode 1 (CD1), for low, medium torque demand, uses only MGB. For CD2, for high torque demand, both MGA and MGB are used. When you fully depress the accelerator pedal in either Normal or Sport mode you create high torgue demand, MGA and MGB would be engaged.
My understanding is the Gen 1 Volt is capable of full performance using only the single large traction motor MGB. The smaller motor, MGA, is clutched into the drivetrain under conditions where its use will improve efficiency. Sport vs Normal is a performance choice, so I would expect the Gen 1 acceleration sprints to be performed in one-motor configuration.
The Gen 2 Volt, on the other hand, uses MGA to meet performance demands, as mentioned above by jcanoe. I would suspect that switching to Sport mode in a Gen 2 Volt could well move the vehicle into the torque demand mapping area that utilizes both motors for acceleration sprints.
Other than how much you need to depress the go pedal it has never been shown that the Volt accelerates any faster in Sport mode.
· Super Moderator
2012 Std w Nav
The modes in that video have nothing to do with the "drive mode" that the button involves. The car will use either propulsion mode as it sees as appropriate regardless of the "driving mode" setting.
1 - 10 of 10 Posts
