1 - 3 of 3 Posts
The AM radio stations on my 2017 Volt are almost un-listenable. There is SO much interference that about the only way I can listen to an AM station is to turn off the heater.
There's some kind of buzz that doesn't allow the station to come in if my heater/blower is on. If I turn it completely off, then AM stations are at least listenable. BUT... there's still a LOT of static.
Has a resistor or some kind of electronic part failed in my radio? Do you get clear AM radio channels in your Volt?
The Morgan.
The Morgan.
I think the problem is with the heater / blower. Try turning on just the blower with no heat. Does the interference occur? If yes, then it's probably the blower motor. I don't think a blower motor normally causes interference, so if you determine that is the problem replacing the blower might fix it.
try with car OFF and see this post
if signal is weak then a possible wiring or connection problem.
1 - 3 of 3 Posts
