Anyone know if the 2017 Volt has the same Key FOB programing steps as the Gen 1 Volt?
Do you need two metallic keys (step 2 and 3) for the process to work?
___________________________________________________________________________
Programming with a Recognized Transmitter
A new transmitter can be programmed to the vehicle when there is one recognized transmitter. For vehicles sold in Canada, two recognized transmitters are required to program a new transmitter. To program, the vehicle must be off and all of the transmitters, both currently recognized and new, must be in the vehicle.
1. Place the recognized transmitter(s) in the cupholder.
2. Insert the vehicle key of the new transmitter into the key lock cylinder on the outside of the driver door and turn the key to the unlock position five times within 10 seconds.
The Driver Information Center (DIC) displays READY FOR REMOTE #2, 3, 4 or 5.
3. Remove the rubber mat in the instrument panel storage. Extend the key blade on the new transmitter and insert the key blade into the transmitter slot.
4. Press and hold the POWER button on the center stack for two seconds. When the transmitter is programmed, the DIC will show that it is ready to program the next transmitter.
5. Remove the transmitter from the transmitter slot and press UNLOCK on the transmitter.
To program additional transmitters, repeat steps 3 through 5.
When all additional transmitters are programmed, press and hold the POWER button for 10 seconds to exit programming mode.
