1 - 9 of 9 Posts
Took delivery of my black 2017 Volt LT at the end of June, 2016. Car has close to 5000 km on the odometer and am extremely pleased with the performance so far. Have had one serious problem though. On 3 separate occasions the entire display (speedometer and information display screen) have blacked out briefly (for several minutes one time and for several seconds the other two) only to return intact. Have taken to my dealer for analysis to no avail. The computer scan showed no problem and they had no remedy or opinion as to the cause. Has anyone else had this experience and if so what is the cause and solution?
· Administrator
Loose connector/wire?
It may not be relevant to your concern, but on Gen 1 volts, the daytime/nighttime sensor will sometimes switch the headlights on due low lighting conditions, or shadows from trees/buildings/clouds. when it does this, the displays switch to the physical setting of the display dimmer, which if it is all the way turned down, can be very dim, appearing to disappear in some cars. I've had this happen to me. something to check at least, try turning the dimmer up the next time this happens.
· Administrator
In the G2 Volt forum there have been a few threads similar to your experience.
I've had my G2 volt about a year. I had several freezes in the first few months of ownership. It was fixed by walking away from the vehicle with your key fob a distance maybe 100ft or more for some time 10 minutes plus and the screen seemed to reset. This walk away strategy worked for a number of volt owners while others prefered to pull infotainment fuses.
In march, my dealer tried to do the Android Auto update and messed up by having wrong type of usb flash drive. As a result, they corrupted the HMI and needed to replace it. After i had my HMI module replaced, I haven't had any freezes. It has been rock solid. Maybe coincidence maybe not. Hope you get your problem figured out soon.
P.s. when your screen goes out, in a pinch you can use your steering wheel controls and DIC to scroll through your stations and media if needed. Its a cluncky work around but helpful if it happens during a long commute. Good luck
I have also had a few problems with the center display / rear camera on my 2017 LT. The dealer talked to the Voltec hot line and they said it was an issue they have seen in vehicles but don't have a fix at this time. FWIW I picture a spandex clad caped superhero picking up a yellow phone in the shape of a lightening bolt on the other end of the Voltec Hot Line. Ok maybe I watched the Batman TV show too much as a kid.
The main reason I took it in was for an oil leak, Really? an oil leak in a brand new car? is this 2016 or 1986? grrr! Bad Chevy! Shame on you!
1 - 9 of 9 Posts
