Hello all. Just purchased this CPO vehicle through Carvana. It has 29,300 miles. I've been charging it at 8 amps at work on an EVSE charger. It will fully charge in 4-5 hours and the light is solid green. It will absolutely not charge to the 53 Mi EV battery capacity thus far. It was a bit warmer today while at work so I figured it would charge beyond where it's been capping out at during these colder weather temps... which is 45 mi. It was around 65 degrees and sunny today. So I figured maybe it would venture beyond that 45 Mi threshold. It didn't. I assume that the previous owner (only 1 previous owner) maybe overcharged it and possibly left it charging in warm to hot weather all too often. It's around 8 percent degradation at this stage.
Should I wait until it's 70-85 degrees out to fully test this true EV battery threshold and see if it goes beyond 45 Mi? Or bring it to a mechanic to test its true degradation? It's under warranty still, plus extended warranty.
Thanks!
Thanks!
