I know it's actually a darn good car. I really want mine back..there is nothing like it out right now. It's a shame the cancelled it.
I would expect it is a latent manufacturing issue. The challenge to make more new BECMs would be chip availability, most likely... Though I did see somebody theorize some BECM vs. 12V battery system (bad 12V battery, low voltage, or 12V battery charger issues interacting with an overly sensitive BECM) as a possible cause of BECM failures which would be interesting.We are not sure yet what the failure mode was on the modules. If it was just poor soldering as was suggested that is easy to fix. Parts are hard to come by currently and all it takes is one missing component for the module and it can't be built.
My BECM failure moments happened on extreme cold days, and I did have slightly low 12V battery voltage, which made me assume the problem was just the 12V getting old. From what I've read, cold brings out the BECM issues because of the solder contracting, but it'd be interesting if it had to do with 12V battery interactions (ex. BECM having to function outside of its parameters in some way to compensate for 12V battery condition).I would expect it is a latent manufacturing issue. The challenge to make more new BECMs would be chip availability, most likely... Though I did see somebody theorize some BECM vs. 12V battery system (bad 12V battery, low voltage, or 12V battery charger issues interacting with an overly sensitive BECM) as a possible cause of BECM failures which would be interesting.
-Charlie
I just got mine repaired after a 50-day wait. Yay!My BECM failure moments happened on extreme cold days, and I did have slightly low 12V battery voltage, which made me assume the problem was just the 12V getting old. From what I've read, cold brings out the BECM issues because of the solder contracting, but it'd be interesting if it had to do with 12V battery interactions (ex. BECM having to function outside of its parameters in some way to compensate for 12V battery condition).
If you're trying to keep under warranty, I'd stick to something close to OEM 12V so that you're not opening a door for a warranty denial.Greetings!
My 2017 Volt is dead too due to BECM problem. It's about 42k miles on it.
Does someone know if the Voltec warranty covers vehicles outside US and Canada?
As for 12V battery influence, maybe changing it to LiFePo4 battery will do the thing? Weight reduction as a bonus.
The base mechanism is the same in a bunch of GM vehicles - just different trim/knobs snapped on the top.Stands to reason if a faulty micro switch is used in more than one car, they can both experience a problem. Other's have repaired their own for a few dollars and some time.
I think this is the 6th or 10th musing about a class action lawsuit. I have yet to see any action taken. Keep us posted...I did reach out to a lawyer who is interested in a class action suit. He reached out to a national firm who is also very interested and thinks it's a strong case. Nothing signed yet.
Message me if you're interested in more info.
