So, I went on a 10 day vacation out of town and left my 2016 Volt at a friend's house near the airport. We got back after 10 days (I left it in her driveway, not plugged in), and the Volt was completely dead ... fob would not work. I had never had to use the mechanical key before (THAT was fun figuring out at 10pm in the pitch black in the rain!). So, I got the front door open, and my friend got her jumper cables ... opened the hood -- no battery
Ah yes, battery is in the back ... but how to open the hatch with no battery??!! I couldn't. So, I ended up running the jumper cables through the back door and out into the hatch (not much fun ....). I was able to successfully jump it, and then drive home 60 miles. But after this experience I have some questions for the Volt experts on the forum:
1) Am I mistaken, or shouldn't the Volt (or any car) be able to handle 10 days without an electric hookup WITHOUT fully draining? The battery is the stock 60 month Delco ... and I've ready comments here on the forum before that it's "weak" ... thoughts?
2) Should I take it to the dealer to replace it with another lame battery? Or should I just go ahead and invest in a high performance battery?
3) I'm curious now about HOW the Volt charges the 'small' battery: I typically run on lithium battery only propulsion about 90% of the time ... if the alternator is not spinning (ie: the ICE is not running), how does the small battery charge up?? Is there a trickle that runs from the big lithium battery? Or ?
4) Does anybody know a mechanical mechanism to open the rear hatch? out in the real world with a dead battery, not being able to open the hatch for a jump start is a royal PIA !!
thanks in advance ...
Jd
Jd
