I've had a reoccurring issue with my Volt. A few weeks ago I went to start my car after work and the "Initalizing, wait to shift" message popped up on the dash, followed by the engine trying to start up. After 5-10 seconds, the engine will stop trying to start and the car will be in "accessory mode" and had to be towed to the nearest dealer. They fixed it the first time saying they had to replace the "engine computer" (I believe?).
Well two days later, Christmas day no less, the car does the same thing. Right before I finalized the tow truck, the car started normally with a check engine light, and I drove it to the dealer near my house. The dealer now told me the 12V battery needed replacing as it wasn't putting out. They are going to replace the battery and try to read the codes when the car is able to start, hopefully.
Does that seem like something the battery would cause or is there something else at play? I had a bad habit of leaving the fob in the car for extended periods of time
so was wondering if that would cause the battery to drain enough to cause the problems I mentioned.
